What gear box will fit ??
As per titel what gearbox will fit a ph1 172 ?? Will a 182 drop in ? And difference in ratios etc , not bothered about top end at all , any help most appreciated ta
Yes seen that myself lad up Liverpool way can't remember his name owns about 80 cars lol he dropped the whole engine in too !
I'm a little out of touch with the 172/182's now, but I know they all fit, but the 182 uses a different speedo sensor. So you won't get a reading if you use that, unless you drill the box and fit your ph1 connection.
172 Cup has the best/shorter ratios. Although I feel the ph1 box is ideal.
