What bulbs do I need to change indicator bulbs on my 200?
You wanna get some Silvertec indicator bulbs. The are silver as opposed to the orange standard ones but still flash orange.
You need fitting type BU5815 as it has the offset pins we require.
You can get 'em from Halfords or online.
There are some cheaper versions available on amazon that a few people on here are using and say they're better than silver tec. They are easy to change though.
i think if ur changin the front and back, they are different, the one set has the offset pins and the other has the straight pins.
How do you remove the rear light cluster to change the indicator bulbs in them?
open boot, 3 screws holding the light on, undo these and remove light.
WARNING : BE VERY CAREFUL WHEN REMOVING REAR CLUSTERS !!
they are quite fragile and I ended up cracking the lense when trying to get it off. Not best pleased as it was not the one I broke whilst shovelling snow. I have 2 brand new genuine ones ready to go on now though courtesy of Karl !
Searched for this and got 0 results on google pml
Also guys in halfords had never heard of it?!
I got mine on eBay, about £3 a pair or something. You want 581's, they are offset pins. The others (straight pins) are 382's.
