Stainless Brembo Bleed Nipples
Tarticmonkey
Folks,
As some may have seen I snapped a bleed nipple in a Brembo calliper over the week. This has now been sorted.
This has lead me to think would something this be a worthwhile upgrade? Or will these still have the same issues?
You will still get galvanic corrosion, but no more or less than what the originals do.
I imagine the car will be someone else's problem by the time they would start to cause a headache tbh.
After having this happen to mine I usually crack them off every so often to make sure they don't seize up over time. Put some anti seize on there too just to make sure.
Stainless Steel threads can gaul, however, I have never used St Stl in Aluminium so not aware if it will be a problem or not.
