Just joined the forum so felt the need to do my first post. Sprayed my calipers blue at the weekend
Looks good well done, only issue i see is thats a 1K finish.....god knows what temp thats rated to, not alot i imagine. 2K lacquers, generally ~100c, might yellow after that and eventually fail.
I did a 2K finish on my rear calipers, with decals, but they only get touch hot (~60c maybe), they are still fine over a year on, even after a good owning, but i did go through a serious prep process lol (sand blast, etch primer, 2k primer, 2k black, 2k lacquer).
The fronts would be a different matter, chances are that will start smoking if you go to a track or a hardcore drive.
If i was DIYing, id use a VHT paint and not lacquered.....as i dont know of a lacquer that can stand high brake temps, atleast generally available.
Cheers,
Simon @ SS
Sprayed alloys + wheel cleaner? | Clio 197 Area | 9 | ||
Show me your sprayed dash trims | Interior and Audio | 80 | ||
Where to get refurb and sprayed around Kent/Oxford? | Wheels and Tyres | 3 | ||
Had a few things sprayed | Interior and Audio | 16 | ||
Photos Wanted - RS 200 with cup alloys sprayed black | Gallery | 9 |
