Can anyone tell me of any shorter final drives for the Clio 200 gripper make one but it wasmade for rally cars so takes top speed to 108mph.
Ideally want top speed 130@7600 ish.
Yeah that's the one, 1.6 Scenic with a TL4 021. FD is 4.733, & spot on compromise tbh - although probably wouldn't want it if I commuted!
Nice, keep wanting to do Spa myself but then keep not having anything working all summer long But I think you'd need somewhere like Spa to try a vmax for sure, I don't think any of the UK tracks are long enough unless running upwards of I guess at least 260?
I did all but vmax it in "Germany", pretty much the last time I used it!
For £100-£150 for a TL4 021 well worth doing if you track it, and don't mind 70@4kish for road duties.
There is no need. Speed reading is taken from the wheels not the gearbox. Unless I've misunderstood your post.Picking this thread up rather than starting a new one, is there a speedo gear swap or electronic correction that can be used to correct the speedo with a 4.7?
Brill, thanks mate.
These new-fangled cars are clever aren’t they!!
No worries. Have you sorted a FD for yours? I'll probably be stripping my gearbox down this summer and removing my shorter FD.
I haven’t mate, let me know if and when yours becomes available. Dare I ask about the whole box or is it a case of if you have to ask you can’t afford it?
Not so New member finally in a Clio | New Members | 0 | ||
Finally got a Clio RS!! | New Members | 0 | ||
Final Drive Ratios 5:0:1 needed for Clio 3 RS | Clio 197 Area | 5 | ||
anyone use a 4.7 final drive | Engine, Gearbox, Exhaust and Air Intake | 4 | ||
C | Shorter Final Drive | Engine, Gearbox, Exhaust and Air Intake | 7 |
