Hi folks.
The inner CV boot on my right hand side driveshaft is split. It's a 2009 RS200.
Is this inner boot replaceable, or does it require a new driveshaft? And does anyone have the correct part number? I'm seeing conflicting information around.
My plan was:
Thanks
My plan was:
- undo lower balljoint on hub
- remove driveshaft (Does the driveshaft just pull out after removing the big nut holding it to the hub? And do I need to drain the transmission oil when removing the right hand driveshaft?)
- Remove old boot, pull the joint apart and put a new boot on- but this is where I'm not sure if it's replacable?
- Any additional tips are welcome!
Thanks
