Renault Sport Clio 197 Racing Red
You have to check the bolt! I think you used the standard M8 bolt? It will definitely break! We drilled a bigger hole and used a M10... but it was also broken after one rally. Now I am using a M12 12.9 ...
It broke?
I'll fit a bigger bolt eventually, but it seemed to me there was no excess stress on the lower mount...
Will try and make it bigger when I remove the fog lights so I don't need to remove the bumper twice. :wink:
TNX for the tip.
Buy a Megane they said...you'll be fast, they said...:giggle:
[video]https://youtu.be/3BzCQI8ln1Y[/video]
[video]https://youtu.be/tFYKSPqlQpU[/video]
[video]https://youtu.be/5ZNl8p5i53Q[/video]
[video]https://youtu.be/KhsIor3wKwA[/video]
[video]https://youtu.be/8EIOzqDoB_8[/video]
Lols at the last one where you gave him the finger :smiley:
you have a seriously fast clio there mate. Only the 320hp one was faster really...
GROBNIK STREET RACE
BBQ and friend's set of wheels:
Full retard mode:
He came to be the prettiest one - didn't race:
This one came to be the fattest (me), and to make lunch :d
Clio Spor means Clio slow in Croatian. :smile:
Dinner:
My best time AFAIK (didn't get all of the slips) , although I had to brake in the finals and made 15,0TT:
1st place 15 class, 1st place 14 class , 3rd place 15 class
[video]https://youtu.be/FobUc1VJsF8[/video]
Been busy today...I had my intake manifold ported and matched couple of years ago and since I've changed an engine. This one doesn't have a ported cylinder head ergo - the intake on the head and the inlet manifold ports didn't match. Till today.
Intake manifold:
Cylinder head, "ported" vs stock (the 2 on the right). :smiley:
STOCK
"PORTED"
My idea was just to remove that "step" between the ported and matched intake manifold and the cylinder head. Of course, I blocked the passage to the valves so the aluminium residue doesn't enter the cylinder, and the rest I vacuumed with the vacuum cleaner. :smiley:
Impressions? TBH, my butt dyno says that I have a better throttle response, and MAYBE some more kick at >5krpm.
You are a nut case taking a die grinder to the head whilst fitted to the car!!
Looks like you've gained a fair amount of port area though. As long as gas speed isn't hurt too much for low to mid range, it'll help up top for sure.
Hello
your clio is amazing :smile:
but please tell me why 215/40/17 not 215/45/17?
TNX. :wink:
Because it's like installing a shorter final drive.
And it'll look nicer when OZ Alleggerita's come (because they look one size smaller due to their design).
Yep, I know. :smile:
I've put a sock in every port, used a vacuum cleaner and an air blower afterwards.
Couple of mods left to do on the car this year (if my finances allow me to :smiley: ) performance vise (custom intake manifold, head work and a remap). I believe I could squeeze out a 10-15bhp more.
And the next year I'll probably make/buy a lightweight flywheel and that's it for the engine. I believe/hope it'll be as fast as a Megane 275, and that's enough for me.
For now. :smiley:
