morning luke,
This is quite a common fault for the radio to stop working in extreme cold conditions. My hunch is that the fuse will be fine just disconnect the battery then reconnect. if it asks for radio code just enter it and hey presto. The fuse box is located to the left of the steering wheel inside a panel. the radio fuse is i think the fourth one up on the left hand side. it should be 15 amp. hope this helps.
I just took out the fuse, thinking it was that, but no, they were both fine. Hopped in the car to goto Halfrauds to buy a new stereo, engine on, thought i'd give the radio one last try, and it came up with "Code"
