Loose lower ball joint in hub carrier.
Hi all, i have a problem with clio 200 from 2011, here in the weekend installed new lower ball joints in the hub carrier, but the ball joint it self is not secure in the hub carrier so i can move. So my question is, do i need a new hub carrier or may this be a wrong part?
I have painted a mark on the ball joint so its may be easier to see what i mean.
Thanks! IMG_0097.jpgIMG_0098.jpghub
Unfortunately no, the ball joint are bought from ktec racing, its there oe spec one if it has anything to say.
old ones where pressed out, but the new one i could press in with a finger.?
That’s not correct bud, they definitely need pressing in. Does it have a part number or any stampings on it?
Hub carrier is probably knackered. I changed one not too long ago which was really loose
They need to be pressed in
Honestly I’ve no idea. I thought i was missing something when I went to put the new one in
