Fernandez
Gold Member
As a few of you have experienced the bottom and top swivels on the hub carrier can and do fail.
My drivers side started to creak when turning full lock, a quick call to Renault and I was quoted £180 for each half of the complete hub carrier assembly as Renault do not supply the parts individually. Obviously this is quite an expensive job when you factor in the fitting on top.
What Renault don't tell you is you can get swivel bearings from R-Sport for £58 each delivered but then you still need to fit them.
Enter the perfect solution......
My car has been with the infamous Mark Black for the last few days, for those that don't know, Mark is very well known over Meganesport for his sterling work on all Renaultsports and has been refurbishing the Megane hubs for the lads over there.
Mark is now able to source the parts required and fit both the top and bottom swivels to forum members for £125 per hub which represents a fantastic saving over the prices from Renault or R-Sport
Mark is based in Chesterfield right next to Jct 29a of the M1 so quite central and the work can be done whilst you wait.
To take advantage of this price just give Mark a ring at Bolsover Car Care on 01246 823 464 and either mention me or that you are a member of Clio197.net to get this preferential rate.
