how to fit a de cat pipe??
It's a straight forward clamp, two ends butt together on the manifold/decat. You use the existing standard clamp, then you just do the clamp up. the side you'll have to have a fiddle with (the hard work is already done with mine) you have to cut the exhaust the middle box side. The decat is already flared, so you'll just cut the exhaust side by the middle box and the decat just slides onto it. Then you'll just put a clamp around that join.
It's too long! I think the one I've got off Gez is for a standard exhaust, I have the cat back. The flange on the de cat and exhaust system is the same size!
Mine has fused itself! Best off buying a new lambda sensor and keep the old one on the cat for a really quick exchange for mot time. That's what I'm gonna do anyway.
