Oil catch can, whos fitted one?
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by Doogle, Jun 28, 2018.
  1. Doogle
    461
    Plymouth
    Car:
    BMW e46 330cd
    Hey all,
    I have been thinking about fitting an oil catch can. How does it work with the PCV system? I have seen it setup on some but not sure how it works, my impression is the PCV almost sucks the vapor out of the block.
  2. Big Ben
    4,834
    Herts
    Car:
    197
    @Yiannis197 might be able to help. I’m sure he has/had one
  3. Daverb
    Daverb
    354
    Fife, Scotland
    Car:
    Clio 197
    Me. Coke can
  4. Doogle
    461
    Plymouth
    Car:
    BMW e46 330cd
    Any pics? :laughing:
  5. steve11
    steve11
    568
    Oz
    Car:
    CLIO RS200-T & MEGANE RS275-R
    Here’s pic of the one I fitted to my 200:
    And the one I fitted to my 275:
    Hyde200 likes this.
  6. Doogle
    461
    Plymouth
    Car:
    BMW e46 330cd
    Steve, so to get the plumbing right, one end connects to the outlet on the back of the engine and goes to the catch can, the other hose runs from PCV valve to the catch can?
  7. TB Rich
    TB Rich
    2,049
    Bournemouth
    Car:
    Clio 200
    You don't have to route back to the inlet manifold (well to stay road legal you might have to) as it is preferable not to really. I run a catch tank without routing back to the inlet, as the oil vapours do nothing but dilute the charge and cause more knock sensitivity. Not such a problem if you're at standard compression (mine was higher comp), but it's not for performance reasons they route the vapours back in - it's part of the emissions systems for crankcase vapours etc.
    If the catch tank has a proper substrate for slowing and cooling the vapour to collect the oil properly, then you can route back to the inlet as it should be pretty much clean air, however most catch tanks are just empty voids, in which case I'd not route back to the inlet. Stick a breather filter on one of the ports off the catch tank, or something like a Mocal tank has a breathable lid.
    Shameless ITB pic aside, but you can see where mine is mounted currently at the back where the airbox would normally sit. This is not routed back to the inlet - as there is no where to route it for a start anymore! - but as said even on the plenum I did not route back to it, and I used a silicone cap on the port off the plenum to blank it.
    Cap on plenum:
  8. Doogle
    461
    Plymouth
    Car:
    BMW e46 330cd
    Thanks for explaining it Rich. I think my concern was that from what I have read about a positive crankcase ventilation system (and I may havr interpreted it the wrong way) is that the vapours are pulled out and pushed into the inlet by the PCV. I know the vapours will naturally rise out but as the best place to mount it seems to be by the main engine mount on the offside thats a fair bit of hosing. I was worried the hose would clog?
    I was intrigued to see why Steve11 has rerouted it back into the inlet as opposed to the atomsphere via a filter?
    My cars on 117k now, anything I can do to help preserve power and gain any little bit is a good thing.
  9. TB Rich
    TB Rich
    2,049
    Bournemouth
    Car:
    Clio 200
    yeah I suppose as the port on the plenum is pre TB it will always experience vacuum on the PCV pulling the vapours, I would assume the widget on the side is some sort of restrictor valve mind as it would seem like a substantial amount of pull otherwise?
    I also remember Ashford told me that on their high spec engines that make more power and rev higher they actually weld a larger -10 AN fitting on to improve crankcase breathing, however for more regular specs the standard elbow off the back is apparently large enough to do the job just fine.
    While I was at Pure I got one of their fancy billet crankcase covers with a -10 AN fitting on it, but tbh it was purely for the shiny-shiny and not as I felt I needed it as such! Nice having a proper AN fitting too as it meant the hose could match the fuel and oil lines which are being done in ProGold black & gold crimped fittings. I'll get some pics when the catch tank is re-installed and plumbed back in.
    I'd guess the long return Steve has would not block but just in winter and short stop start journeys you'd get that oil/condensation build up in the line, goes a bit like mayonnaise. Probably not a problem for Steve mind as he's in Australia!
    Doogle likes this.
  10. Doogle
    461
    Plymouth
    Car:
    BMW e46 330cd
    Id definately rather go for a simpler setup, one hose to a can with a proper system to vent to the atmosphere. Theres so many different sizes, any recommendations?
  11. TB Rich
    TB Rich
    2,049
    Bournemouth
    Car:
    Clio 200
    Get 1ltr as a minimum tbh. Assuming you're not racing, as some regs I've seen call for a 2ltr minimum if not running back to the inlet manifold.
    Mocal makes life easy with it's breathable lid, plus a few different anodised colours never hurts :wink: Although I'm quite the fan of Radium stuff now, fantastic quality to the parts and machining.
  12. Daverb
    Daverb
    354
    Fife, Scotland
    Car:
    Clio 197
    They do cost a fortune though.
    The Clio Cups used this:
    If you want bling go for bling but it doesnt need to be anything fancy.
  13. TB Rich
    TB Rich
    2,049
    Bournemouth
    Car:
    Clio 200
    Builds a race car with a sequential box(?).....uses milk bottle and zip ties for breather tank :tearsofjoy: You're right you don't need 'fancy', but then there's just plain ghetto too! lol
  14. Daverb
    Daverb
    354
    Fife, Scotland
    Car:
    Clio 197
    Yeah Renaultsport must have been painting somewhere lol
  • Share This Page
