Help !
Joshluff
Yesterday my car decided not to start I've checked the fuel sender unit and that works I also get fuel up until the fuel rail. But I get no fuel in the fuel rail can anyone help as I'm now lost for what it could be ? Is it electrical ?
Could also be the crack sensor on the gear box (underside). Mine went A while ago then last month the connector came loose. Re fitted the connector and it started straight away. No error codes showing on computer as it doesn't give a code for some reason.
