Diffuser issues
Discussion in 'Clio 197 Area' started by Jools, Jan 13, 2018.
  1. Jools
    Jools Gold Member
    116
    Worthing
    Car:
    2006 clio197
    guys.had the 197 a few weeks,new it had a blow in the exhaust somewhere,took it to ATS this morning up on ramp the two basic clamps around centre ish exhaust are on pissed and rusted up good with small blow coming from the worst one easy fix,the guys there wanted to check around the back box itself but couldn’t undo the two 13mm nuts at back of diffuser rusted on properly.
    He didn’t want to go to mad trying coz he thinks the two bolts nuts screw on to are captive I.e. welded or something to body of car and if he snapped them them I’d have more problems,sprayed up good with penetrating stuff but still couldn’t undo.
    Does anyone have any knowledge on how those nuts are set up and any words of wisdom on solutions for this anything would be much appreciated
  2. turkie172
    turkie172 Paid Member
    652
    N. Ireland
    Car:
    197
    That's what your dealing with just take it slow and easy tighten then loosen and keep doing that give the threads a good wire brush to clean them out it's repairable weld another stud on and cable tie it with heavy ties if the worst happens until it's fixed. Not hard to try the nuts if you drive the rear wheels up on something and slide under it's the clips around the bumper that need care and attention even refitting so you don't bend one because it use not in it's slot.
  3. Jools
    Jools Gold Member
    116
    Worthing
    Car:
    2006 clio197
    That circled bit is where a stud was welded?
  4. Jools
    Jools Gold Member
    116
    Worthing
    Car:
    2006 clio197
    Ok I see the stud now
  5. turkie172
    652
    N. Ireland
    Car:
    197
    It's pointing away from you the only pick I could find check the threads someone may have used the wrong type of threaded nut and just wound it on.
  6. Jools
    Jools Gold Member
    116
    Worthing
    Car:
    2006 clio197
    Yeah maybe.i think it just hasn’t been touched in years this motor needs a lot of attention
  7. MarcB
    MarcB Gold Member
    292
    Scotland
    Car:
    LY 197 F1 / Trophy / Escort RST
    I took mine to my renault specialist and they said its a very common issue.
    What they do is they snap the nut off the bolt and then re-wild a new bolt onto the bracket and then apply a new nylon nut.
    Mine are take off every few months and then there is a blob of grease put on the bolt and pop a new nylon nut back on.
  8. Jools
    Jools Gold Member
    116
    Worthing
    Car:
    2006 clio197
    Cool
  • Share This Page
