Check Injector
As above really, anyone know what this could be.
Weird thing is if it happens and you switch the car on and off it sorts itself out
the fact you are not sure indicates that you probably dont have one..
Sprint Booster
they are known for throwing this msg on you dash when connected improperly.
have you read the fault codes?
if its p0300 (i think) you may not find out the issue!
"''How often do you have to turn off the A/C in order to cross quickly a road with traffic?''
Sorry WHAT!? :grinning::grin::grin::grin:
Ah so nothing can solve it, would a remap not solve it either
not really there could be an underlying issue...or like mine ...it did it on a couple of occasions especially when hot...
all you can do is read the codes and check what it has put up and delete them off and run it until it happens again
that assuming its been serviced and plugs changed when they are supposed to be
