That looks really worn at the back and has the rubber split too at the front, did you say you'd had that shock replaced too?
Well after all that it was the top mount!they should of spotted that though when the shock was replaced.Yeah i had the shock replaced you would think that this would have stuck out I'm going back to see the garage tomorrow morning to see were I stand on this hopping there not gonna try and charge me for this. When I rang the garage they said it would be a strip down again 2 hours what should of happened is the garage should have spotted this when removing the shock and I wouldn't have had a problem paying for the part but hey at least I know my hubs all good lol
I would get a garage to do it be a cock on doing it on your drive on your own well thats what i did anyway.Try BRIAN LEIGHTON a trader on here for the top mounts might do you a good deal,I replaced both just to be on the safe side.Is it easy to change too mounts then or better to get it done at a garage? Any part numbers?
What am I missing? Is the mount loose?
only trouble with the 197/200 is that the suspension is so hard and I think a lot of the damping shocks get transmitted in to the top damper mount....hence why
Renault modified the newer 200s to the smaller/modified/stronger strut top....
new member - can't see for sale? | Clio General Chat | 2 | ||
S | Still can't cancel membership | Questions, Bugs and Suggestions | 8 | |
B | Can't remove shock/strut | Clio 197 Area | 6 | |
Can't access forum threads? | Questions, Bugs and Suggestions | 3 | ||
B | Can't remove brake pad | Clio 197 Area | 2 |
