bugs and waterspots
Is there a product specifically for removing dried water spots?.
Also what is considered the best bug remover, preferably something that dissolves, rather than rubbing.
A polish works well for removing waterspots!
Failing that, and not wishing to dissolve your wax/sealant, try something you can apply over a wax - sonus acrylic glanz works for me!
Not sure about bug remover, I find my normal washing routine limits the amount of bug splat.
Ok, I don't mind polishing, its what to use as the car marks so easy, what's available that's kind to the paint, but will move waterspots.
I have some megs scratch x2, but not sure about doing a larger area with it.
The problem bugs are the ones that can't be immediately washed off, they bake on and I don't like rubbing at em, so if I can find something that dissolves....
This is the best QD I've used. Perfect for removing water spots or a quick spruce up. Smells awesome too: CLICK
Really good bug/tar remover. You just squirt it on and after 30 seconds you wipe the area clean. No rubbing required: CLICK
Nik Questions, Bugs and Suggestions 92
MikeDX Questions, Bugs and Suggestions 72
Roger200 Detailing 11
