Addison
Once it is definitely, until then I'll probably want to curl up and cry!Sounds like you're well prepared, I'm sure it'll be very satisfying once its all in and working!
Nice set on the bay from renbreakers for 60 gold coinsThose rear lights are something else absolutely beautiful, need to get some for mine.
How did you get around the fog light issue?Nice set on the bay from renbreakers for 60 gold coins
You can either rotate the pins on the plug or there's someone called Brad Brown on Facebook who's in the groups who sells a harness to do the same thing essentially without messing with the original harness. I just bought the harness from him to keep it OEM for the sake of £13How did you get around the fog light issue?
Looks like you’ve got more camber on the rear
Hahaha, getting softer as I get older. Like to be comfy these days!Like the slippers that pure shifter looks like the real bollocks.
It was the first thing I checked out when I got the car and I was surprised of the condition granted the milage on it!To be honest that rad support actually looks fairly tidy mate. However, there's no harm in trying I suppose. Atleast if it does get done then it'll be sorted for a long time rather than waiting for that one too eventually go!
RPD, it was about £35 IIRC!Can I ask where you got the rear view mirror from? Mines a bit crappy
Where does it end? 2003 Clio 172 | Projects & Progress | 3 | ||
S | S88THL - Supercharged Clio 200 | Projects/Progress Threads | 3 | |
Wiring Diagram for 197/200 Wipers | Body Work and Exterior Lights | 1 | ||
S | will a 197 diffuser fit on clio 200 | Body Work and Exterior Lights | 16 | |
Addy's Daily 200 Project | Projects/Progress Threads | 47 |
