200 exhaust trim
remove diffuser
you may have to unbolt the exhaust funnels to get to the trim locating tabs
then push in the locating tabs on the trims and pull out
its very simple. Remove the 4 bolts holding the diffuser on, unclip the er .. clips holding it to the bumper. The the rings are held on by 3 spring like cips. Bit of pressure and they pop out of position and slide out through the hole the exhaust comes out. No need to remove the funnels. Strangely, the Akrapovic replacements are a better fit than the renault ones, if thats what your doing?? :bounce:
