197/200 Buying Guide
Check out PistonsHead.com for a well thought out and comprehensive guide(they say you should only use 99 octane fuel only).
There SHOULD have been a aditional sheet of paper in the manual stating 98 and over.
high octane is only for the best performance and cold running...they do run on the cheap stuff :foxspeed:
This is the error:
Standard specification was generous, and included four piston Standard specification was generous, and included four piston Brembo front brake calipers with 305mm vented discs, rear disc brakes
This is the error:
thanks but looks like the error has been corrected
any other things that are not right or think need added please let us know
Ignoring the error in my post due to using my phone, I understand front discs are 312mm and rear 300mm... Can't see the error corrected.
