xeonon headlights change
Hi all,
It may be a silly question though I wondered is it possible to change back to standard headlights from my current xeonon headlights (Clio 197 07)? Im getting flashed quite allow because people there so bright.
Andrew
If your getting flashed a lot then they're probably not self leveling properly and pointing to the sky... Common fault, do a search there are plenty of threads about it... sensors front and back, back one being easiest to get at.
In terms of downgrading the headlamps are a straight swap but might not solve the problem... And you wont be able to see at night with two candles for lights, lol.
First you need to let us know are they factory fitted xenon headlights or HID bulb upgrades or have you fitted factory xenon headlights into a normal 197 without the xenon levelling sensors and headlight washer systems. I hope you have not fitted HID kit into open reflector headlights instead of projector headlights
Reactions: Chris
