xenon leveling
Few weeks ago i fitted some xenon lights , plugged and play they worked how ever there was a small plug either side that didnt fit because my last lights where bog standard.
my question is are those to do with the leveling and can i get them to work ?
my lights where brand new from the dealers so do i need anything else as they have been pointing at the floor for weeks not to good.
leigh
So you bought renault xenons? Yeah it will be the levelling sensor thats not attached that is located back passenger side just infront of axle....massive job mate.
Make sure the height sensor is fitted to the lights from your old lights if you didn't get a new one and that the bracket inside the lamp unit isn't all loose and flopping around. If all is in then you can adjust height with a screw driver on the height sensor itself. Its the little black motor on the back of the lamps in between the bulb holders. Can get to it from the top
of course aswel the new lamp unit wont have the height adjustment motor in them as well, you have to swap them over.
