Wishbones on 197 200
Hi all can anyone confirm whether the bolt holes on the wishbone subframe mounts should look like this. cheers. just put a brand new wishbone on, and car has failed mot for play in wishbone bush.
Seeing as this got solved in (they're not meant to look like that) another thread, posting the link here: https://clio197.net/threads/suspension-arms.62497/
it didnt really get solved did it. no one has categorically said whether this is normal. if anything people have said its not normal. i have seen pictures of brand new mk2 subframes and the same hole is elongated . so to be honest with you any advice ive had off here has been pretty much vagueand guess work by everyone.
Ah ok, I stand corrected. The reply you got seemed fairly authoritative so I thought it was done.
Interested to discover the answer because the elongated slot doesn’t look like it was worn.
