Hiya,
I need to replace my wishbone and also part number 1 on the schematic below. I found the wishbones already from RPD, but can I clarify with you guys the exact name of the part which I need.
It's part number 1 in the above schematic. Would i
be correct in saying that the part I need is this one below:
https://k-tecracing.com/products/oe...-suspension-ball-joint?variant=43236204773615
The "lower hub pivot"? Or is it the "lower arm suspension ball joint"
Or if not either of those can you point me in the right direction please?
Many thanks in advance
