will they fit?
The 17's in that size will just fit but but will be close to the arches. You'll only be able to run 215/45/17's as 225/45/17 will rub.
The Renault bore hole is 60.1 which is different to Ford and Volvo so you'll need spigot rings.
The 18's won't fit as the wheel is 8j with a bigger offset so they'll no doubt poke out.
