will clio v6 wheels fit the clio 200 ?
From cliov6.net
Wheels
MK1 and MK2 PCD
5 x 108 , 60.1 centre bore
MK 1 17" OZ
Front - Part number 6020010228 (£321.70 + vat)
Rear - Part number 6020010229 (£321.70 + vat)
Offset Front ET 20
Offset Rear ET 50
Mk 2 18" OZ
Front - Part number 6020012088 (£332.43 + vat)
Rear - Part number - 6020012089 (£338.68 + vat)
Offset Front ET 6
Offset Rear ET 68
I know the 200 is 5x108 but the offset im not sure..
For future ref, the front wheels on either of those (mk1 or 2) would not fit, they would stick out far, far too much, the mk1 by about 40mm the mk2 about 55mm
Don't know what the widths are but if they are an 8" rim you'd only get any joy with two pairs of rears from the mk2, you might be lucky with two pairs of rears from the mk1.
:driveby:
are they really that wide ??
It's not the width it's the offset. it is in effect a RWD car, different to our FWD cars.
Hence the different offsets.
Our wheels as standard are 7.5J, thats width with an offset of et68 and 5x108 PCD, thats pitch circle diameter, an imaginary circle through the mounting bolts.
So 5 bolts in an 108mm diameter circle.
In theory the rears would sort of fit but the fronts definitly not. The offset on them is massive. Just think there only 7 wide but fill the arches on a v6 and underneath is just normal clio suspension.
Rick
