Where To Get It Serviced In The Yorkshire Area?
Anyone recommend anywhere for a 6k oil change on my 200?
Im based in Huddersfield, but can obviously travel to somewhere recommended
Thanks in advance :biggrin:
You arent that far from Harrats Wakey on Denby Dale road, might as well take it there.
Three decent options there and I would agree with all of them! Used both the Harratts and I highly recommend them but DIY is something you could always try - it will definitely be cheaper!
Well im a techy for Audi, but id like a stamp in the book to say its been done, and our labour rates are sky high. Ive been to Harratts Wakey before but wondered about a specialist locally?
The only specialist I know of locally is Queens Service Renault in Stourton, Leeds. However I haven't ever used them myself so I can't recommend.
just use the audi stamp.......and diy it!
Can't recommend Harratt's in Wakefield enough - a dealer that deserves repeat business.
Shame the same can't be said of the Pontefract branch......
If it is only a 6k oil change then the stamp isn't important as you aren't actually doing a service, unless there is a special place for interim oil changes?
as above not sure if its an actual service but you could try DDC (doncaster diagnostics centre) which is a renault specialist and they recently serviced mine, very good imo.
