Wheels 7,5j et40
I belive the standard wheels are et68 but they are a 7.5x17 so same width as yours.
What this means is these other wheels will stick out 28mm more than standard so you'd have to check if you have 28mm of clearance for them to fit.
From what i've read on here people put either 16mm or 25mm spacers on standard wheels but with the 25mm spacers they run close to the arch.
Yours would stick out a further 3mm so you'd be 3mm closer to the arch.
They could just catch.
