Are you going for the bolt to hub spacers (hub centric style), if so then your standard wheel bolts will be perfect.
if you are going for a spacer where you have to bolt through the spacer to fix to the hub, just whizz out one of your bolts, measure it and add 20mm.
they are also M14.
HTH's.
