Upstream oxygen sensor
alex.murphy2011
Mines just failed , can get a genuine one from work for around £135 (Bit steep)
Part number 8200830903
Anyone got any new ones spare they’re willing to sell ?
alex.murphy2011
What car have you got (197/200) and where are you at as the direct bosch ones are around £50 - £60 new don't go by the part number on the body of the lambda and there can be a difference on the connector type oval or more square there is a section here somewhere with the bosch part numbers.
https://clio197.net/threads/o2-sensor-troubles.55027/#post-614769
I
That’s my car :smile:. Yeah I didn’t realise the different connectors till I checked yesterday , I actually work for Renault as a seniour tech but with discount it’s still expensive , the part number 8200830903 fits this one with the correct type of connector , but didn’t realise the Bosch ones were that cheap! Thanks very much for the help
turkie172
Yea don't go by the part number on the body of the lambda they use the same sensor but vary the configuration of length and connector type I bought the wrong ones going by the body part number and ended up ordering the connectors and changing them on my 197 I don't know why I ordered the wrong part I did know the difference but changing the connector fixed the problem.
J Clio 197 Area 2
Similar threads
Oxygen sensor Diagram
