Upper Torque Arm - Bushes
Torque Arm is visibly slack, thinking of just swapping out bushes for powerflex in the first instance or is the arm itself known to be weak?
Plenty have changed the bush for Powerflex, including me, and the difference is instantly noticeable. Never heard anything re. the actual arm failing.
Yeah easy enough to change the bush, 30/45 min job!
As said above difference is amazing, just beware you do get som vibrations inside the car, but they do get better after a few hundred miles :smile:
