200cup andy
has anyone else noticed that the upper engine mount on the drivers side seems a bit soft. i realised that alot time when you lift off you can feel the engine rock about, i had a look under the bonnet and you can push the mount about quite easily with your hand
im wondering what would happen if the gaps in the rubber mount on the engine are filled with something to make it stiffer would it stop all the hopping about
