Brunoandrade98
Hi all,
*Apologies for the fairly repetitive posts, but I'd like to make sure I've done everything I could*
My 197 feels sluggish, and has for pretty much since I've owned it. A few months ago, I did a compression test and all cylinders showed 125-ish PSI consistently on all 4 cylinders. I had a garage double check it for me and they got 140PSI - Not sure which will be the more accurate, but my gauge was a brand new Sealey one - Wet test showed figures of 180+PSI across all cylinders on my gauge (can't remember the garage's wet figures), which points to piston ring wear
While this isn't great and I should expect performance loss, I'm not sure if it should be as bad as it is now. I find that the car is very lazy setting off from first but becomes more responsive when higher on the revs. Hard to explain, but I feel that the throttle doesn't do much at low revs when driving off in first and the throttle feels unresponsive.
It's also happened a few times where the car misfires/flatspots at random times, more noticeable when going uphill, where the car stops accelerating and just shudders despite me being on the throttle.
I have a CLIP, so can look at live data, but not sure what I'm looking for, however I did notice that my throttle only goes up to 89.8% when I press it all the way down. I test drove another 197 on similar mileage (unsure on compression figures, but doubt it's been well kept all its life) and despite having a flat spot due to having a de-cat manifold, it felt much more responsive when driving off and more lively higher up the revs as well.
Maybe mine will never be like that until I replace the engine, but I feel it shouldn't be this bad either. So far, I've done:
Screenshots attached
Thanks in advance
- Replaced coils - Have not replaced the plugs, but they're only a year old and it was an issue before and after fitting this set
- Fitted a MAP sensor holder, which keeps it in place and apparently helps with misfires and performance issues
- Cleaned throttle body
Thanks in advance
