TC or ESP is dreadful in snow. Better off not using it. That's for pretty much every manufacture.
It just cuts and re inputs the power when slipping so you just spin up in the snow. I can't get on my drive with it on. With it off, straight on.
To be honest if you're relying on traction control in the snow you need to be more gentle on the throttle. As long as you're driving sensibly then traction control will give you no advantage.
ESP could help if the back end steps out but I wouldn't rely on it!
Sorry, but you clearly have no idea what you're talking about. Try taking a 500hp rear wheel drive car onto an ice lake and pull away with traction on, no problem. Repeat with traction switched off, and you just end up polishing the ice! Yes there are differences in TC systems between manufacturers, but from what you've said I'm guessing you just keep burying the throttle and complain when a system doesn't allow you to move away, rather than driving sympathetically and understanding how the system works.
Also, I know how a ESP works too, actually in the process of adjusting the parameters on the New Fabia VRs![]()
As foxspeed has said, ESP is far more capable than you in keeping the car on the road. As well as looking at individual wheel speeds, it also takes into account things such as yaw rate and lateral acceleration.
Take a car onto snow, ice or a very wet road and try a high speed direction changing manoeuvre with and without ESP on, and see which one you drive away from!
even with ESP on it will happily let the tail slide out.
I know how to drive![]()
And after driving, well quite a few of different manufacturers ESP's, the renault one isn't the best.
Also, I know how a ESP works too, actually in the process of adjusting the parameters on the New VRs![]()
