Hello helpful folk, my Clio 200 servicing document says it is time to replace the accessories belt and roller also replace the timing belt and rollers...this may be a silly question but effectively this is the Auxiliary Belt and Tensioner Kit and the timing belt kit? ...I understand it's better to have the water pump replaced while they are in there?
Is there anything else that should be done at the same time? I'm going to an independent garage and want to give them as much into as possible as they are not a Renault specialist.
I was going to use the Gates Powergrip Timing Belt Kit (Improved) ..anyone have experience of this?
http://www.engine-dynamics.com/ServiceParts/pid104947/cid188/GatesPowergripTimingBeltKitImproved.asp
If you happen know what a fair price / time required for fitting these parts that would be awesome.
Thank in advance for any info
