Depends on how you fitted the HIDs.
If you had to drill a hole through the rubber caps to feed the ballast>Bulb wire for the HID then reverting to standard bulbs will leave your headlights unsealed with this hole allowing condensation and engine bay dirt into the headlight unit.
But other than that, the only difference is the bulb type so yes easily changed.
