Fernandez
Gold Member
So what would make the perfect N/A build and how much power/torque could you achieve with the F4r in NA form? You could easily see a 9K rev limit or possibly more.
A few items that look good contenders for the build are:
Some lairy cams.
Forged Rods and Pistons:
http://www.k-tecracing.com/show_product.asp?id=3931&appid=3
Catcam finger followers:
http://www.catcams.co.uk/acatalog/Latest_News.html#a403
Valves:
http://www.engine-dynamics.com/EngineComponents/pid100313/cid111/UpratedStainlessSteelandIconelValveSet.asp
Solid lifter/lash cap set:
http://www.engine-dynamics.com/EngineComponents/pid100242/cid111/CatcamsSolidLifter/LashCapSet.asp
Cat cam Springs:
http://www.engine-dynamics.com/EngineComponents/pid3/cid111/CatcamsUpratedValveSpringSet16.asp
obviously its not just about those parts, I'm sure there's some head work to consider, in fact you need to modify the head to fit the catcam followers.
What else would need to be considered? Head gasket? Bearings? Head bolts? Stand alone ecu? I guess the list could be endless and yes you could buy another car for the cost but that's not what this post is about.
Some lairy cams.
Valves:
Cat cam Springs:
