Supercharger Kit Proline Motorsport
Could anyone that has had a supercharger long term comment on the long term health?
Im constantly dithering as to whether to get a supercharger / Megane engine / or just swap back to a Megane 250
My ideal would be a charged clio as I prefer the small size, less stable chassis, and the na delivery. Just very hard to get a gauge on the longevity
There’s quite a few people running supercharger setups these days and I’ve not heard of any horror stories.
I’ve seen one blow up on the rollers but that was chasing some big figures... forged bottom end but standard top.
Aside that so far they’ve been reasonable well! Not how many miles people have done
Hi I’ve just got mine back forged engine from andy at engine dynamics great Bloke and it’s supercharged had sc fitted somewhere else can’t say who at moment but that company couldn’t get it running right .so took it to engine dynamics he’s got it running good.
doing 347bhp got donnington next Sunday to test out hopefully everything is good
DigitalDaz, did you go stage 1 or 2 on the engine from andy and what supercharger and pulleys are you running?
Forged Piston Set (11.3 CR)
Forged Con Rod set with ARP Bolts
Catcams Uprated Valve Spring Set
MLS Head Gasket / Seal set
Cylinder Head Chemical clean and valves seated
Hydraulic Lifter set
Head Bolt Set
Engine Block Chemical clean
Lower Engine Gasket / seal set
King Crankshaft Big Ends
King Crankshaft Mains
Crankshaft thrust washers
Timing Belt Kit
Dephaser VVT Pulley
Oil Pump
Water Pump
Cat cams 403
Updated valves
Head Bolt Set
Timing Belt Kit
Dephaser VVT Pulley
Oil Pump
Water Pump
Cat cams 403
Updated valves
You really went for it then! Was it all done by Andy?
Head Bolt Set
Timing Belt Kit
Dephaser VVT Pulley
Oil Pump
Water Pump
Cat cams 403
Updated valves
Yes got it done andy is great bloke
Need to get used to car as totally different car I’ll post some pictures later also had fuel swirl pot pump fitted
Had supercharger full cage paddle clutch and fuel system fitted at ktec
Engine dynamics did engine rebuild and mapped it up
