I was getting some buzzing from my rear speakers, so bought some anti-squeak tape from eBay to eliminate it.
1. Removing rear grilles - I did this using my fingernails. This helps prevent you from snapping the plastic. Be patient...they will pop out!
2. Applied anti squeak tape. I cut this in half as it comes quite wide. Then I applied it all the way around the back of the grille using my nails to ensure the tape adhered to the part that sits against the car.
3. Whilst I had the grille off, I added a sheet of silent coat to the outer skin. There is a pad added by the factory, but I added this stuff as it worked well in previous installs:
4. Clicked it all back together and it now has no rattles at all!
Problem solved!
Problem solved!
