Sticker
There are larger versions too, a large one that goes across the rear panel. If you do get that instead of the one Jimmy has posted, be sure to get a body shop to do it if you're not handy with stuff like that. Would be a shame to ruin it and lose 30 quid or less.
Piece of piss to apply, water, few drops of washing up liquid, and a squeegee ( sign applicator tool ).
Totally agree with [MENTION=51574]cliovirgin[/MENTION] as long as bodywork is clean they are so easy to fit its unreal.
Couple of drops of Fairly Liquid ( other brands are available ) added to water in a spray bottle from the pound shop. Lightly spray the clean area you are going to place the decal then as you peal the backing off the decal give the adhesive side a light spray too. Place the decal in the desired position then use the squeegee from the centre out wards to remove all the water from under the decal. Robert is mothers brother :smile:
