What size bolts would I need in order to fit 16mm spacers?
930Tech CLIO CUP groupee. Platinum Member Jan 29, 2012 #2 The thread or lenght? The thread is an odd M14X1.5 but lenght unsure. But to be safe you'll want at least 16mm longer than standard.
930Tech CLIO CUP groupee. Platinum Member Jan 29, 2012 #3 If you have locking bolts (like i have) measure one of your old ones in the packet.
Gareth_197 Jan 29, 2012 #4 You would need 41mm bolts, std ones are 25mm long (thread length) i know you can get 40mm bolts, havent seen 41mm though. Gareth.
