Soft Front Brakes
Never thoght the front brakes where very good / sharp
Took the wheels off and pleanty left on the pads
Finnaly had enough and bought some EBC pads & Pins (thank you Mr Pink)
Fitted today
Found out why the brakes where soft
The pad material was braking up and comming away from the pads
See pics of original pads
So if you have soft brakes, change them before they fall apart
Took the wheels of
Looked down at the pads in place, no problems, pleanty left
Only found out they where breaking apart when the pads came out
Do you take the pads out annually and look at them
Took the wheels of
yep!
complete front and rear strip - giving a visual is practically worthless
That is impressive
Got a bit worried about the rears now
Thought the front was just a bad batch, maybe its heat build up from braking that has done it.
What other areas do you do an annual check on
That is impressive
done plenty of front brakes on clio/meganes and its common for them to fall apart...
rears usually start to seize up due to dirt/brake dust etc
I always did a yearly service and brake strip (front & rear) plus wheel/tyre rotation
I also used to clean the air box out as it collects in the bottom of it
brakes are the major problem if left for long periods
