Size of standard exhaust tips
Clarki99
Bit of a random question I know but what are the diameter of the standard Mk3 200 exhausts pipes...not the main system just the exit tips.
I have a single Oreca race system that will be up for sale soon as going to try one of Pure Motorsports straight through systems.
On the Mk3 200 diffuser there are two brackets that the exhaust tips sit in (the round brackets attach with two screws to the diffuser) and had to remove one to fit the Oreca system but looks like I binned it but other side still has it fitted.
I know the Pure system is 2.25" compared to most other after market at 2.5" so wondered if will fit in the brackets like standard OEM system.
All that needs to be done is cut the pipe shorter as long as it goes well into the funnels it should be ok with the outer rings in place other option is a 197 diffuser.
