TB Rich
I replaced my b pillar trim and the side window trim along the bottom of the window because I broke the clip on it. The new one is not fitting as flush as the passenger side which I haven't moved.
Is everybody else's trims flush against the b pillar ok? Mine as about a 1mm gap on the new one.
Any tips or suggestions to improve the fit? I don't really want to use a silicone or anything like that, as I might aswell have just kept the old one if I do that! Also it might excert a pulling force on the vinyl and over time allow water to ingress and bubble.
[MENTION=8494]smithandroper[/MENTION] just putting your name here guys as I bought the trim from you.
Cheers.
Cheers.
