197: Seatbelt alarm Query
Discussion in 'Clio General Chat' started by Dean Cohen, Sep 9, 2019.
  1. Dean Cohen
    Dean Cohen Paid Member
    43
    Shropshire
    Car:
    Clio 197
    Bit of a silly question and probably the opposite of what people would normally ask.
    Is there supposed to be a warning alarm when the seatbelt is not clipped in on both the drivers side and passengers side?
    Drivers side does beep when belt is not clipped in but passenger doesn't and ideally I would like the car to remind passengers to wear a seatbelt (safety first!)
    If it should be working on the passenger side too is there anything I should check?
    I suspect maybe a loose cable as the airbag light comes on occasionally until I give the cable a wiggle.
  2. Beany
    Beany Platinum Member
    2,162
    Doncaster
    Car:
    RB 200 cup
    No it only bleeps for the driver... not sure if it can be retro fitted.
  3. Dean Cohen
    43
    Shropshire
    Car:
    Clio 197
    Thanks for confirming this, probably more hassle than it is worth to retrofit I imagine?
  • Share This Page
