Sagging driver's door
Brunoandrade98
Hi all,
My driver door sags when I open it, dropping down slightly, which makes it difficult to close.
Is there a way to adjust it properly, rather than just jacking it up, essentially "forcing" it into alignment?
Thanks in advance
Just remove the front wheel arch liners you can access the bolts with a spanner from the wheel well. I've done this don't undo the bolts too much so when you lift the door and get it to close you can tighten again without needing someone to hold it.
