Yeh where the bolt is on the side of the mount the bit around bolt, its like hooked onto the mount
ryan197 POW right in the kisser Platinum Member Jun 28, 2013 #21 Yeh where the bolt is on the side of the mount the bit around bolt, its like hooked onto the mount
OiNK Jun 30, 2013 #22 Hmmm, still not sure what you mean, I had a look at mine, here is a picture of it... Don't see what you mean by a cover or understand what bit could be loose...
ryan197 POW right in the kisser Platinum Member Jun 30, 2013 #23 The bit with the square hole in which the bolt and rubber sit behind
