Removing arch liners
Hey!
I had the front wheel off earlier trying to get the plastic liner out. I have seen it done at the garage but I can't for the life of my pull these things out.
They're like rubber patches but are somehow attached...
Thanks for any help on this - anyone had these out?
They just pop off with a gentle persuasion from a flat head screwdriver. There's a few more dotted around you'll need to remove. Then its a case of prizing the edge out and taking out from there
I normally use pliers. They'll probably break but just buy some off eBay, they're cheap enough.
I think there's two which you can't see easily. Located 'sort of' behind the wheel.
Sorted it chaps. Out of 4 pins, 2 survived unbroken. They're rubbish. It's securely held in though.
Thanks for the help. Now on the lookout for some push pins. Oh and I'm off to the car wash :wink:
