Semi! will this fit on a 200!? I mind the vauxhall boys could get different inlet manifolds from a company ( cannot mind who ) with great gains, hmm...
wonder if theres any benefit in having the top half of the standard 197/200 inlet done like that?????
dbilas or irmscher?
after driving home from work tonight i lifted the bonnet and put my hand on the plenum and it was cold,on the top anyway! its was 20 degrees plus outside so thought this was quite good,the underside was very hot but then again it would be so it looks like mike might have a real point in making gaps between the legs to cool from the underside,can someone do me a favour and put there hand on there plenum after a spirited drive and roughly tell me how hot to the touch it gets,cheers
This is normal.
I found out that the more you push the car and if the ambient temperature is <25°C the inlets are far from hot.
However, they tend to get hotter when stopping at traffic lights (no airflow).
they told me it was not worth it on a 197 thats why they wouldn't develop one. and angel if you contact stone automotive on clio sport he still makes the rs2 and sells them on his own web site
Today I have logged plenum temperatures with an OBD bluetooth reader & Torque.
It seems that at 22-27C environment temperature and at 40-50km/h average speed my plenum temperature varies between 52-65C.
Did anyone else log their temperatures in similar conditions?
how did u measure these temps?
you've lost me
Inlet Plenum Removal Broken MAP sensor | Engine, Gearbox, Exhaust and Air Intake | 0 | |
Inlet plenum | Engine, Gearbox, Exhaust and Air Intake | 2 | |
inlet temperature reducing | Engine, Gearbox, Exhaust and Air Intake | 3 |
