Rear wheel bearing help
Bought a rear wheel bearing from eurocarparts
went to have it pressed an it don't fit, says it should be 62mm and the one I bought is 52mm any ideas?
I have a damaged mtec rear disc that has never been fitted the abs ring was damaged and I got sent another one so it's just lying about the garage, [MENTION=4573]kjl1987[/MENTION] brand new and never been fitted, pm if interested :smile: sure you could press the bearing out and reinsert it in your disc
I'd advise you get a new rear disk. Yes you can get bearings and press them in but they are never going to be as good as factory made unit.
Eurocarparts sell the OEM SNR disks at a fraction of what Renault will charge for exactly the same part
Renaultsport sell the bearings separately for about £36 plus vat but not the abs ring.
